Date/Time: Mon, 06 May 2024 01:43:50 +0000
vs 1939
View Count: 632
[2019-06-25 14:04:42] |
Crtfyd - Posts: 277 |
FYI Thanks for adding the "Extend to EOD" in "Color Bar based on Alert Condition". However the "Right Edge" for Value Label doesn't work for the Extension line(SG2)or(SG1). Nor does the "Values Scale" for the Value Label.
[2019-06-25 17:12:16] |
John - SC Support - Posts: 31379 |
We have found the solution to this and it will be in the next Pre-Release (v 1940). When available, you can update using the Fast Update. Refer to the instructions here: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
