Date/Time: Fri, 03 May 2024 13:23:20 +0000
[User Discussion] - Volume by Price -- Weekly Profile, Reference 1 Period back strange result
View Count: 984
[2019-06-25 13:00:11] |
RonW - Posts: 103 |
I opened a new Intraday Chart for ES September futures. Chart Settings: - Days to load 100 - Bar Period 30 minutes - Un-check use evening session - check automatically rollover futures symbol - choose continuous contract date rule rollover, back adjusted Volume by Price Input 33 Multiple Profiles Based on Fixed Time Input 34 Weeks This works fine. Now when I make a change: Input 31 1 I get this: http://www.sierrachart.com/image.php?Image=1561467418835.png I tried changing the scale on the study from automatic to same as region, but that doesn't have an effect. Any suggestions? Thanks |
[2019-06-26 03:27:44] |
Refer to the documentation for this Input: Number Of Periods Back To Reference You need to adjust this Input accordingly: Minimum Time Period % for Reference Days Back Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
