Date/Time: Wed, 08 May 2024 04:55:00 +0000
Data Not Far Enough Back
View Count: 681
[2019-06-24 15:48:21] |
User9415867 - Posts: 38 |
I have an indicator that doesn't seem to calculate when I use above the DAILY time frame. It just doesn't show up. I have attached my settings and screen shots to show. The 1st is the DAILY which works. Then the 2nd is the settings for the DAILY bars. The third is when it disappears and doesn't show data or bars beyond a certain date with 5 days as the bar? I also attached the settings for that one which the only change in settings is 1 day to 5 days.
Date Time Of Last Edit: 2019-06-24 15:49:20
2019-06-24_114407.png / V - Attached On 2019-06-24 15:47:24 UTC - Size: 34.49 KB - 244 views 2019-06-24_114425.png / V - Attached On 2019-06-24 15:47:28 UTC - Size: 28.51 KB - 240 views |
[2019-06-24 15:49:02] |
Pictures 3 and 4
2019-06-24_114447.png / V - Attached On 2019-06-24 15:48:41 UTC - Size: 45.62 KB - 233 views 2019-06-24_114457.png / V - Attached On 2019-06-24 15:48:46 UTC - Size: 28.78 KB - 224 views Attachment Deleted. |
[2019-06-24 15:57:11] |
Follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-24 16:51:31] |
Thanks. When I try to extend the total days and the date range it doesn't work. Am I missing something?
[2019-06-24 17:10:47] |
Follow steps 2 through 6 here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Instructions to Download/View More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-24 17:18:19] |
This appears to work. Is there a way I can do the 'Edit >> Delete All Data And Download' for all 200 symbols at once instead of 1 by 1?
[2019-06-24 17:32:25] |
the best thing to do would be to disconnect from the data feed with File >> Disconnect and delete the data files through File>> Open Intraday Chart: Chart Data and Chart Data Files Connect to the data feed and as you use those symbols, fresh data will be downloaded. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-24 17:32:26] |
The best thing to do would be to disconnect from the data feed with File >> Disconnect and delete the data files through File>> Open Intraday Chart: Chart Data and Chart Data Files: Deleting a Chart Data File Connect to the data feed and as you use those symbols, fresh data will be downloaded. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-24 17:32:52
