Date/Time: Sun, 28 Apr 2024 07:37:05 +0000
Total Volume & Chart DOM Columns
View Count: 1065
[2019-06-24 05:32:19] |
Acro - Posts: 436 |
Hi, I wanted to check the only way to get a column for the day's total volumes at each price level into or adjacent to the chart DOM is to add a volume by price study, align it to the right hand side, choose volume profile outline and then choose a color that is the same as the chart background ? I was trying to replicate how well the volume profile appears inside a Trade DOM but on a Chart DOM and I don't think there is any way to do that ??? |
[2019-06-27 13:06:29] |
Yes this is correct. The Volume by Price study is the only accurate way to do this. How you configure the colors is up to you.
