Date/Time: Mon, 29 Apr 2024 06:24:42 +0000
[User Discussion] - Chart Symbol on Chart Background
View Count: 1224
[2019-06-23 15:08:30] |
User703334 - Posts: 59 |
Is there a way to show the Chart symbol in the upper left hand corner of the chart in very large, but perhaps 80% transparent font? Or, perhaps in the chart background?
[2019-06-23 15:19:51] |
Sawtooth - Posts: 3982 |
You can use the Text Display for Study study. -Set 'Use Text for Non-Zero Value to Yes. -Manually enter the symbol in the 'Non-Zero Value Text' field. |
[2019-06-23 17:06:29] |
Thanks.. I followed your directions and I end up with a light blue vertical rectangle in upper left hand corner of chart. The text I enter into "enter non zero value text," is not appearing. I tried adjusting the Subgraphs to no avail. The text I tried entering was "ES" Appears I'm missing something? |
[2019-06-23 17:31:30] |
Did you set 'Use Text for Non-Zero Value to Yes?
Date Time Of Last Edit: 2019-06-23 17:35:55
Text Display.PNG / V - Attached On 2019-06-23 17:35:48 UTC - Size: 49.89 KB - 280 views |
[2019-06-23 19:41:42] |
Yes
[2019-06-23 19:44:30] |
..forgot the attachment. See attached
Capture.JPG / V - Attached On 2019-06-23 19:44:17 UTC - Size: 190.85 KB - 299 views |
[2019-06-23 19:49:42] |
User907968 - Posts: 802 |
You could also use the 'Symbol Display' study Symbol Display |
[2019-06-23 20:07:41] |
That one works, thanks!
