Date/Time: Sat, 04 May 2024 19:05:58 +0000
Moving from 32 to 64 Bit
View Count: 621
[2019-06-22 08:51:20] |
User92573 - Posts: 483 |
Dear Support, I've read the Engineering posts on this subject but would be grateful for some further clarity. 1) I have numerous custom 32 bit DLL's 2) The study collections applied to each chart can have 20+ studies including: a) Numerous 32 Bit DLL's. b) Text display for studies c) Color Background d) Bar Difference e) Price overlays etc. Pretty much all of these are in some way dependent on, or call a specific/associated DLL function name. Here are my questions: 1) How will this situation be affected on changing from 32 to 64? 2) If the DLLs are renamed the the various studies will not reference the correct DLL. How do I address this? In short, how do I seamlessly make the move - in a structured fashion - while at the same time preventing everything from falling apart so to speak? Kindest regards |
[2019-06-22 19:29:28] |
1. Not at all. Going from 32-bit to 64-bit is totally irrelevant in regards to your question. 2. This is automatically managed by Sierra Chart. There is nothing special to do. The 64-bit DLLs will automatically be referenced and loaded. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-22 19:30:01
