Date/Time: Mon, 06 May 2024 20:40:02 +0000
backtest issues
View Count: 938
[2019-06-21 13:36:57] |
User512854 - Posts: 24 |
hi, when we run backtest, we see window "enter bar processing increment" default is 250 if we run 250 then run 2500000 the results are totally different why is that? what bar processing increment means in first place? thank you |
[2019-06-24 18:00:47] |
Is this for a Bar Based back test? We want you to update to the current version following these instructions here: Software Download: Fast Update And see if using the new version makes any difference. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
