Date/Time: Sat, 04 May 2024 16:53:15 +0000
format setting, tick size setting for forex currencies
View Count: 988
[2019-06-21 12:53:32] |
User364859 - Posts: 26 |
Hello How have I to set the tick size for currencies and whatis the correct format setting on the chart setting windows. I use fxcm demo account Thank you for your quick help Walter Zegg |
[2019-06-22 03:09:47] |
The default Tick Size should work properly. What Forex symbol are you referring to?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-22 03:09:54
[2019-06-23 04:40:36] |
Hello I use the major EUR- GBP- USD- pairs . May bee you can send me a sheet with all the parameters Thank you Walter |
[2019-06-24 23:28:08] |
Why do you need to change the defaults?
