Date/Time: Fri, 03 May 2024 15:55:39 +0000
GetStudyArray and GetStudyArrayFromChart : Clarification of Operation
View Count: 1114
[2013-11-30 00:33:50] |
Kiwi - Posts: 374 |
Are these assumptions correct please: 1. study arrays are maintained in ram so access is fast via pointer arithmetic 2. a call to the GetStudyArray or its variants just maps a pointer to an array existing in ram rather than copying an array 3. a call to the GetStudyArrayFromChart just maps a pointer to an array existing in ram rather than copying an array 4. if an array is copied, how much is copied each time the call is made? Thanks; I'm trying to make sure I take an efficient approach to a new project. |
[2013-11-30 01:30:00] |
1, 2, 3. Yes. 4. No copy occurs. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
