Date/Time: Fri, 03 May 2024 23:28:35 +0000
Issues executing trades for MESU19 with Sierra Charts/CQG #2
View Count: 623
[2019-06-20 16:57:11] |
User703334 - Posts: 59 |
I'm having the same issue today with not being able to execute a trade using WebAPI. The error message is different from yesterday (see attached). How can I execute orders? Thank you |
Order error message.JPG / V - Attached On 2019-06-20 16:56:05 UTC - Size: 32.13 KB - 247 views |
[2019-06-20 18:52:54] |
You need to open a separate chart for that symbol you are trading. This has to do with how the CQG system works.
