Date/Time: Mon, 29 Apr 2024 17:48:32 +0000
market depth historical
View Count: 532
[2019-06-20 12:49:22] |
User884550 - Posts: 149 |
does it only record the data live when Sierra is running? Cant I download it from yesterday if I was not running Sierra at that time? Where is it stored? Can I copy recorded depth data between different PCs? |
[2019-06-20 18:59:11] |
does it only record the data live when Sierra is running? Yes. Historical data is not yet provided.The data is stored in the /Data/MarketDepthData subfolder within the Sierra Chart installation folder. Yes you can copy the files between Sierra Chart installations. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-20 18:59:48
