Date/Time: Thu, 09 May 2024 01:46:51 +0000
Third Party Studies Enabled For Account - how to delete it
View Count: 775
[2019-06-20 05:30:51] |
User567294 - Posts: 47 |
once I have set up file to enable download it every time I start my SC, but I want to delete it now, how can I do that? thanks Rex |
[2019-06-20 16:42:01] |
You can enable and disable file downloading for third-party studies here: https://www.sierrachart.com/UserControlPanel.php?page=EnabledCustomStudies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-20 18:04:33] |
Sierra Chart - Max - Posts: 5608 |
If you want a particular study to be removed from your account, just start an account support ticket: https://www.sierrachart.com/UserControlPanel.php?page=SupportTickets And let us know which study you would want to remove. Sierra Chart Support |
