Date/Time: Sun, 28 Apr 2024 19:00:16 +0000
incorrect poistion display on my DOM for sierra charts CQGWEBAPI
View Count: 532
[2019-06-20 00:48:48] |
User811521 - Posts: 1 |
How come this short position is showing on my DOM? I contacted AMP futures trade desk and they show me flat.
Date Time Of Last Edit: 2019-06-20 16:51:57
Gold position showing on platform.jpg / V - Attached On 2019-06-20 00:47:23 UTC - Size: 203.76 KB - 335 views |
[2019-06-20 18:46:24] |
This looks like you have enabled the Order Fill Calculated Position within the chart. Disable that: If you see an incorrectly reported Trade Position Quantity on a chart, Trade DOM, or on the Trade Window for a chart or Trade DOM, then open the Trade Window and make sure Menu/M >> Settings >> Use Order Fill Calculated Position is disabled/unchecked.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-20 18:51:04
