Date/Time: Sat, 04 May 2024 09:59:21 +0000
order problem
View Count: 531
[2019-06-19 22:21:48] |
User786248 - Posts: 25 |
Hi i had a position closed while my internet was off. Now whenever i put a new position, my sierra chart displays wrong entry and exit fills. ANy way to reset the orders? thanks |
[2019-06-20 03:57:33] |
Refer to this particular section about this: Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities Also you are running an older version of Sierra Chart. Update following these instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-20 03:58:05
