Date/Time: Sat, 04 May 2024 16:06:49 +0000
[User Discussion] - Volume By Price POC difference
View Count: 603
[2019-06-19 15:25:37] |
User703334 - Posts: 59 |
I have two identical VBP profiles drawn on two separate /ES charts with very different Points of Control. Charts: /ES 60 min Use Evening Session with Session times identical Tick size 1 2019-6-7-10:00:00 EST to END One chart POC is 2998 and the other 2922 Which is correct? |
[2019-06-19 22:27:20] |
This is impossible for us to answer. The first thing to do is to make sure there is complete data by re-downloading the data: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Be sure to download data for each contract month. We assume you are using a continuous futures contract chart. So you should not be using one of the back adjusted continuous contract options. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-19 22:27:41
[2019-06-20 16:03:39] |
When I select Edit >> Delete All Data and Download", it lists two contract months (F.us.EPM19 and F.us.EPU19. Do I select both of those? Also, I'm not sure what you mean by "you should not be using one of the back adjusted continuous contract options." Why not? Which option should I be using? Are you referring the options listed under Chart Settings? Thank you |
