Date/Time: Wed, 08 May 2024 07:07:18 +0000
[Locked] - Toolbar & Chartbook Size
View Count: 834
[2019-06-19 14:29:32] |
User915231 - Posts: 4 |
Suddenly today, my toolbar & chartbooks are twice the normal size. All my other apps are normal. I've looked everywhere for a setting that would change both, but can't find it. This is just Sierra Charts
[2019-06-19 18:13:55] |
The change is because the operating system has made a change with its DPI setting. You just need to adjust the Font Sizes: Graphics Settings: Fonts and Text Appearance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-19 18:34:41] |
It's not just the font size. Spaces & chart sizes are increased.
[2019-06-19 18:39:20] |
Make the necessary adjustments in regards to chart bar spacing and window sizes. That should be obvious. We cannot control what your operating system is doing. So it is pointless to point this out to us if the intent is to somehow cause us to fix something we have no control over.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-19 18:39:41
[2019-06-19 19:04:01] |
This isn't the operating system. Word, Excel, Internet Explorer are all normal. Sierra was ok yesterday, but had the problem this morning! How could this possibly be the operating system? Nothing was changed in chart bar spacing and window sizing.
[2019-06-19 19:40:51] |
We knew you were going to say that. It is the operating system. This is with complete certainty especially if you are noticing changing font sizes. The operating system is making some lower-level change causing a change with font sizes. Most likely with the DPI value. Once again this is caused by the operating system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-19 19:42:25
