Date/Time: Mon, 29 Apr 2024 19:15:02 +0000
ACSIL: Member AllWorkingBuyOrdersQuantity of s_SCPositionData allways NULL?
View Count: 513
[2019-06-19 09:14:34] |
TedMar - Posts: 189 |
hi, i tryed to get a result from AllWorkingBuyOrdersQuantity / AllWorkingSellOrdersQuantity, but is allways NULL. Please check if this works correctly in SC Version > v1928 and let me know ? Thnak you Date Time Of Last Edit: 2019-06-19 09:14:55
[2019-06-20 04:14:13] |
This will be solved in the next release.
