Date/Time: Mon, 06 May 2024 04:46:37 +0000
STOXX Europe 600 futures (FXXP)
View Count: 639
[2019-06-19 09:04:42] |
User462869 - Posts: 3 |
Hello, I can't find the STOXX Europe 600 Index futures (FXXP)in my symbol list - I have the the other Eurex index futures but not this one. Could you add it? I'm with AMP and using the SC Futures Order Routing with Data (TT). Thanks! |
[2019-06-19 18:00:04] |
Yes we will get this added.
[2019-06-19 19:01:39] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings So this symbol now will be listed in File >> Find Symbol. However, our servers have to be updated as well and that will not happen until the end of the day. So it will not be possible to trade this symbol just yet but you can get market data now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-19 19:01:59
