Date/Time: Mon, 29 Apr 2024 10:13:51 +0000
Reading InternalOrderID.data
View Count: 1061
[2019-06-18 23:48:54] |
User79074 - Posts: 105 |
I am reading InternalOrderID.data to get the last order id. However, I have noticed sometimes Sierra Chart begins saving the last order id in InternalOrderID2.data. Can it be assumed that the highest InternalOrderID(X).data will contain the last order id?
[2019-06-19 00:05:37] |
We do not recommend using this file directly. It is written on a delay.
[2019-06-19 00:11:45] |
That's fine. I have a way to deal with the delay. Can you please answer the above question?
[2019-06-19 00:23:28] |
I just need to know if InternalOrderID(X).data will always be the latest InternalOrderID file. For example if there is InternalOrderID.data, InternalOrderID2.data, and InternalOrderID3.data, then InternalOrderID3.data is the one with the latest order id? I don't care about the delay.
[2019-06-19 14:57:07] |
The file to read is InternalOrderID2.data. InternalOrderID.data is no longer used.
