Date/Time: Sun, 28 Apr 2024 11:29:46 +0000
Automatic „Rectangle“ for a Range Chart
View Count: 839
[2019-06-18 17:21:31] |
User447052 - Posts: 6 |
Hi SC Support / Everyone, I'm looking a longer time a studie and I don't find anything suitable for my "problem ." I search a option for a automatic „Rectangle“ / alert condition under the following condition: I have a Candlestick Chart / Range Chart and the closing from the Candle must higher or deeper how the last Candle in a Range from 1 – 5 Ticks. See attached a Example Thank you very much for your help! PS. sorry for my english ;) |
Studie_Example.JPG / V - Attached On 2019-06-18 17:18:06 UTC - Size: 114.8 KB - 320 views |
[2019-06-19 20:48:22] |
Although not exactly what you are asking for, you can use the Color Bar Based on Alert Condition study to color the bar a different color when your condition is met. You could also try the Color Background Based on Alert Condition study, which will color the background of those bars that meet your condition. Refer to the following information for these studies: Color Bar Based on Alert Condition Also, refer to the information here for how to setup alerts: Study/Chart Alerts And Scanning Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
