Date/Time: Tue, 07 May 2024 18:16:06 +0000
Chart not Working Properly
View Count: 1058
[2013-11-28 18:41:10] |
User77780 - Posts: 2 |
So I opened sierra charts this morning and they're completely screwed upf or me and I can't figure out how to fix it. I tried restarting everything, removing my studies etc. Any help would be greatly appreciated thanks. Notice the time codes at the bottom are supposed to be set to 15min intervals and it's using the LTC/USD info from BTC-e. Let me know if you need any other info or screen shots from my settings or something. http://www.sierrachart.com/image.php?l=1385664033677.png |
Sierra Pic.jpg / V - Attached On 2013-11-28 18:38:59 UTC - Size: 333.23 KB - 356 views |
[2013-11-28 19:43:32] |
Update Sierra Chart by selecting Help >> Download Prerelease. After the update re-download the data in the chart by selecting Edit >> Delete All Data and Download. One of these two should resolve the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-28 20:16:49] |
That worked, thanks a ton.
