Date/Time: Mon, 29 Apr 2024 06:54:54 +0000
Not Existing Position
View Count: 605
[2019-06-18 11:12:01] |
GPST10 - Posts: 139 |
How to remove non existing position - dax mini - for several days now. amp cqg
[2019-06-18 15:20:01] |
Refer to: Trading Information Windows: Incorrectly Reported Trade Position Quantity Where do you see this incorrectly reported Position Quantity? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-18 16:44:36] |
Inside the Trade Chart in upper left corner where NPL IS ETC
[2019-06-18 16:45:06] |
Account balance etc all is ok
[2019-06-20 16:16:49] |
We are looking into this. Can you let us know at the time you saw this, that your Trade Account had no Positions at all in any symbol? That might be what is leading to the problem.
[2019-06-20 16:26:55] |
I resolved the problem by going in to trade activity and I found one position active without any I'd our numbers , just blank entry and I did locate the same entry in orders page and simply deleted. Thanks |
[2019-06-20 18:33:10] |
The problem could be related to the CQG Position issue which has been resolved and is explained in the notes for 1938 here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1938 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
