Date/Time: Mon, 06 May 2024 00:10:33 +0000
Market Facilitation Index Colored
View Count: 1019
[2019-06-18 11:08:46] |
User133093 - Posts: 11 |
The link in the study description doesn't work. I cannot save it in the data files folder to open the spreadsheet with calculations and values. I'm trying to create an alert condition on this study, which doesn't work on the colors of the bars, but I need the numeral values instead. In my current spreadsheet only values are displayed in the subgraph1 column (for all bar colors), but I also need the rest. Could you help me out on this? Thanks, Juriaan |
[2019-06-18 20:43:58] |
John - SC Support - Posts: 31379 |
Sorry, the location of the file was incorrect in the link. We have corrected this, so if go to that page again (or reload it if it is still up in your browser), you can now select the file and it will save it, so you will be able to open it within Sierra Chart. We are not exactly sure how the spreadsheet will help you, as it does not contain anything that you can't already get yourself by adding the study to the chart and using the Spreadsheet Study. If you are trying to create an alert that is based on the colors, then you have to reproduce the underlying calculations (as described in the documentation for the study) as part of your alert conditions. Here is the link to the documentation that contains the information for how the Market Facilitation Index - Colored is calculated: Market Facilitation Index Colored For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-18 20:56:57
