Date/Time: Thu, 02 May 2024 13:33:02 +0000
TPO IB and IB Extension lines
View Count: 1556
[2019-06-18 09:07:21] |
Dom7364 - Posts: 257 |
Is there a way to extend the IB with horizontal lines and IB projections extension with horizontal lines? There is an option to do so but it works vertically with vertical extensions but does not seem to work with horizontal extension lines.
[2019-06-19 19:52:59] |
The base Initial Balance is only displayed as a Vertical bar on the left side of the TPO Profile. The setting IBR Extension Display Mode applies to the IBR Extensions (as the name indicates), therefore, it defines how the next 4 settings are going to be displayed. This is explained in the documentation starting here: Time Price Opportunity (TPO) Profile Charts: Initial Balance Range Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-19 20:31:22] |
Yes I have read and I get how it is meant to work but it does not work, which is the initial point. Have a try ans you will see that IB extension lines do not work. Further IB extension lines 1/2/3 work but not the original simple IB extension lines
[2019-06-20 17:31:20] |
John - SC Support - Posts: 31293 |
We have tried it, and it works as explained in the documentation. We do not see any issue. If there is something you would like changed, you are welcome to ask, but we cannot make commitments on when something may get done.
[2020-01-28 19:55:04] |
User750920 - Posts: 274 |
I think what DOM7364 is referring to is what I am also looking for - that is the ability to have the Initial Balance (without extensions) display not only a vertical line but also a horizontal line if one chooses and be able to label it on the TPO chart.
