Date/Time: Mon, 29 Apr 2024 20:28:08 +0000
[User Discussion] - Issue/bug Referencing Horizontal Line in alert formula
View Count: 944
[2019-06-18 03:01:30] |
Acro - Posts: 436 |
Hi, I have a horizontal line on a chart with drawing ID # 430 When I write a formula using the last price, eg C< UDID[430].A1 Then the alert does not succeed no matter what I do (ie move the line up and down and recalculate the alert where the last price is clearly lower than the line by a country mile) However, if I change the formula to L < UDID[430].A1 it works as intended Note this is part of a more complex formula but this is the only element that has issues. So my point is that there seems to be a problem referencing C with a UDID but not referencing L Can you please look into this |
[2019-06-18 15:38:07] |
John - SC Support - Posts: 31187 |
We are not able to reproduce this. When we test this, using both the Close (C) and the Low (L) with a Horizontal Line, it works properly. A few questions - Have you tried just this part of the formula to see how it works in your situation? - Where is this formula being used, what particular alert item is this part of (Chart Alert, Study Alert, etc.)? - Is this part of a Custom Study, or is this all being done through the user interface? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-18 16:22:18] |
Also refer to: Study/Chart Alerts And Scanning: The Effect of the Value Format on Identifier Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-18 16:22:26
[2019-06-21 03:20:45] |
Acro - Posts: 436 |
Closing this one. Horizontal Ray is behaving perfectly so I will determine what it was on horizontal line that caused my issues |
