Date/Time: Mon, 06 May 2024 19:57:36 +0000
CLR VERSION SPREADSHEET: SEPERATE SHEET REFERENCING QUESTION
View Count: 1153
[2013-11-28 12:10:05] |
enemyspy - Posts: 304 |
HI here is an example of the formula: =IF(SHEET11!ID4.SG4.3>0,1,0) Here is the issue: If I use the formula on a separate sheet as seen above, it always returns a 0 value. Whereas the identical formula placed on the the same sheet that contains the study reference returns both 1s and 0s and functions correctly. Is the referencing other sheets within the same spreadsheet supported yet? thanks again for the help I have recieved in the past. |
[2013-11-28 16:39:40] |
nevermind I realized it was the capital letters in the "sheet" portion...I like the new study reference method.
