Date/Time: Sat, 27 Apr 2024 18:05:04 +0000
setting up support and resistance chart
View Count: 1660
[2019-06-15 18:29:03] |
User438264 - Posts: 3 |
How do I set up S/R chart?
[2019-06-15 18:29:48] |
[2019-06-16 02:13:02] |
Maybe you are referring to Pivot Point lines? If so, refer to: https://www.sierrachart.com/index.php?page=doc/PivotPoints.html#s223 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
