Date/Time: Mon, 29 Apr 2024 06:39:13 +0000
DVP- Tool // Diagonal Delta Colouring problem
View Count: 671
[2019-06-15 11:49:16] |
Atlan - Posts: 7 |
Hello, I have a problem with the DVP- Tool. I want to set the Bid Volume and Ask Volume Coloring Method (ln:49) to Diagonal Difference of Bid And Ask Volume and try to apply it, it jumps back to None. All the other four colouring methods work just fine. When I set Volume Bar Calculation Method to Diagonal Ask Volume - Bid Volume the colouring wirks but I am not able to see the Total volume. Is there a way to get both in one Study so I can see the Total volume as well as a colouring of the diagonal difference? Thanks in advance and Kind Regards Atlan |
[2019-06-18 16:19:44] |
What you want to do is not supported. We will be updating the documentation to make sure this is clear and that you can only select Diagonal Ask Volume - Bid Volume coloring when the Volume Bar Calculation Method Input is set to Diagonal Difference of Bid and Ask Volume. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-18 16:23:30
[2019-06-18 17:34:31] |
Atlan - Posts: 7 |
Thank you very much for the information. I thought it would be this, but I hoped it would might be a problem in my configuration. Never the less thank you very much for the information. Kind Regards Atlan |
