Date/Time: Fri, 03 May 2024 10:48:18 +0000
orders cancelling through sierra chart on bitmex
View Count: 661
[2019-06-14 13:08:51] |
coin boss - Posts: 19 |
I am placing limit orders that have OCO orders attached. If the limit order is hit the oco orders cancel automatically randomly later in the day with devastating effects sometimes if price is moving in the wrong direction When i check the history for the trade it says sierra used good-till-day order types. Any idea why it is choosing that order type? The orders in my DOM are set to good till cancelled. In gneral trade settings, i have use server side oco orders checked. and server side bracket orders. thanks for your help |
[2019-06-14 13:21:42] |
You need to use Good till Canceled on the Targets tab which is the default. Refer to: Attached Orders: Time In Force We are going to update the order confirmation to indicate the Time in Force for Attached Orders. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-14 15:05:04
