Date/Time: Sun, 05 May 2024 09:30:12 +0000
[Programming Help] - Order fullfill doesn't give alert
View Count: 993
[2019-06-14 09:52:02] |
ILIM KIRGIZ - Posts: 187 |
Dear Sir/Madam, I'm not able to get order fulfill alerts on the alert manager window, I only get stop loss trigger alerts but not order fulfilled alerts. I checked all the relative settings, updated my sierrachart to no avail. You can see the log messages and relevant settings in the attachments. I would appreciate if you can check the problem and give advice about it. Thanks |
[2019-06-14 11:26:55] |
We are not understanding this at all. We do not know why you would get an alert to begin with.
[2019-09-23 10:37:14] |
I handled this. I was referring to getting an alert when Profit Target is reached. On top of that, you have 3 stop types. Stop Stop with Bid/Ask Triggering Stop with the Last Triggering The last two does not invoke a stop loss triggered alert defined in General Trade Settings>Play Alert When Stop is Filled. |
[2019-09-24 12:34:41] |
We have updated the documentation here in regards to this: Global Trade Settings Windows: Play Alert When Stop Filled (Global Settings >> General Trade Settings >> Notifications) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
