Date/Time: Tue, 07 May 2024 18:24:08 +0000
Full recalculations
View Count: 600
[2019-06-14 06:39:35] |
User255315 - Posts: 127 |
Hi SC, a)I would like to know what does the full recalculation (with manual looping) actually do with respect to the following variables: 1.Persistent variables (both for chart and chart study) 2. The chart subgraphs and arrays b)Also could we set persistent variables in the sc.SetDefaults block? would the acsil functions have any effect? Date Time Of Last Edit: 2019-06-14 06:45:08
[2019-06-14 11:12:19] |
1. As documented, no change. 2. They may or may not get cleared. You should assume that all elements need to be updated. b)Also could we set persistent variables in the sc.SetDefaults block? Yes this will work.
