Date/Time: Thu, 02 May 2024 05:08:00 +0000
Position Line
View Count: 1128
[2019-06-13 20:45:39] |
User54459 - Posts: 7 |
Is it possible to make my position line shorter
[2019-06-14 18:04:49] |
If you are referring to the location of the position text and the line that is drawn across the screen, then refer to the following setting: Chart Settings: Trade Drawings Left Align % (Chart >> Chart Settings >> Trading menu) If you are referring to the text that is drawn with the Position line, then refer to this particular setting: https://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#ChartTradeSettings_DisplayProfitLossOnPositionLin Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-14 18:06:43
