Date/Time: Mon, 13 May 2024 12:52:37 +0000
Different commissions for different symbols
View Count: 905
[2019-06-13 11:49:46] |
Vladislav Kravchenko - Posts: 39 |
Hello. How is it possible to write different commissions for different symbols ? I have managed the value of the round turn commissions in Symbol Settings, but it is like the same for all of the symbols and I want for different symbols different commissions. How is it possible to do it? |
[2019-06-14 18:07:38] |
Each symbol or symbol pattern in the Global Symbol Settings can have its own independent commission value. So you should not have a problem with this.
[2019-06-16 09:03:49] |
May be I am doing some thing incorrect. Would you please tell me how to set up commission for each symbol ? |
[2019-06-17 17:52:41] |
For what symbols do you want to set a different commission for? Just tell us two of them.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-17 17:52:57
[2020-06-03 07:05:51] |
User957252 - Posts: 5 |
I am having the same issue. For e.g. I want to set round turn commisions to 2.84 for FDAX and 3.70 for NQ. However, when I change the 'Use Global Round Turn Commission' value for one symbol it automatically propagates to the other. |
[2020-06-03 22:21:50] |
You need to set the commission per symbol. Not using the global round turn commission. You can set the commission per symbol in the Global Symbol Settings. Refer to: Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
