Date/Time: Sun, 28 Apr 2024 14:54:01 +0000
Easy Question
View Count: 657
[2019-06-12 17:37:50] |
Critcendo - Posts: 11 |
Hey, Is it possible to sort those MDI tabs at the top alphabetically? https://www.screencast(dot)com/t/rYxhycocHY Thank you and good night. |
[2019-06-12 18:47:06] |
From your screenshot, it appears you are talking about the Chart tabs, as opposed to the Chartbook tabs. In either case, there is no programmatic way to sort them. But, you can grab and move the tabs around as you want. Also, with the Chart tabs (but not the Chartbook tabs), you can reorder the list using the Window >> Windows and Chartbooks window. Refer to the documentation here for this: Window and CW Menus: Windows and Chartbooks (Window) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
