Date/Time: Sun, 19 May 2024 01:42:54 +0000
SC datafeed available to affiliates
View Count: 1157
[2013-11-27 19:27:42] |
Willson - Posts: 176 |
Wanting to know if datafeed is available when using brokers associated with supported broker? For example OEC is supported, they have many affiliated brokers that use their platform and clearing, like Stage5 broker. So if an SC subscriber uses Stage5 broker, will they be accepted for the SC data feed? Regards |
[2013-11-27 21:00:04] |
Yes. Any OEC affiliated broker will be fine. There are no restrictions on this.
