Date/Time: Sun, 19 May 2024 12:53:49 +0000
Where is LIFO setting?
View Count: 899
[2019-06-10 13:15:20] |
User585019 - Posts: 27 |
Hello, I'm using Version 1820 64 bit and don't see where I can set the Last In First Out trade setting on sim. Someone suggested looking under "Chart Settings" but my panel does not match their screenshot. Please advise. TIA. |
[2019-06-10 13:16:47] |
You need to update to the current version of Sierra Chart for this setting: Software Download: Fast Update Where is it in Sierra Chart that you are looking at trading related values, where this should apply to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-10 13:17:56
