Date/Time: Sun, 19 May 2024 14:30:14 +0000
Alert formula not working.
View Count: 1001
[2019-06-09 23:52:51] |
mittalpa - Posts: 28 |
Hi, This formula works =AND(C>((H[-1]+L[-1])*0.5)) But if I modify formula with 0.51 instead of 0.5 all the color bars disappear =AND(C>((H[-1]+L[-1])*0.51)) Is two decimal multiplication not supported in alert formulas? If not supported, what could be alternative? Thanks |
[2019-06-10 01:39:22] |
This probably relates to the Value Format setting. Refer to: Study/Chart Alerts And Scanning: The Effect of the Value Format on Identifier Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
