Date/Time: Thu, 02 May 2024 19:43:06 +0000
SC Data Feed - Quote When NetChange NetChange% sometimes don't reset day-to-day
View Count: 1135
[2013-11-27 16:40:13] |
drw112 - Posts: 21 |
I am using a QuoteBoard and noticed some odd behavior with the NetChange and NetChange% on some contracts some of the time. It appears that the netchange does not always reset at the Close until the data feed is disconnected and reconnected. Some days it does, some days it doesn't. Today I saw this issue with NQZ3.
[2013-11-28 05:26:48] |
We will look into this and see what the problem is.
[2014-01-08 17:35:24] |
Futures Operator - Posts: 239 |
Was this issue corrected? How is NetChange and NetChange% both on the QuoteBoard and on each chart window calculated? I've noticed they are often different. Is it affected by session times? |
[2014-01-08 18:24:22] |
Yes it was. Make sure you are on the current version of Sierra Chart. How they are calculated depends upon the particular Data or Trading service you are using. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-08 21:49:47] |
I am using SC/TT on v1072. The NetChange on my daily chart matches the QuoteBoard, but the intraday charts all show something different. How is it calculated for those?
Date Time Of Last Edit: 2014-01-08 21:58:31
[2014-01-08 22:05:02] |
To get a match to the Quote Board you need to add the Chart Header field Daily Net Change.
