Date/Time: Sun, 19 May 2024 15:10:38 +0000
Chart not showing correct time display
View Count: 926
[2019-06-07 19:52:15] |
arruga - Posts: 249 |
Hi I got SPY, for example, with intraday session times in symbol settings as default: NY time zone, 09:30 to 15:59 In Data trading service, I got my Time Zone defined as Brisbane (+10) Then, on the chart--> chart settings, session times appear fine, with session times displaying in Brisbane time zone, which is my global timezone, and I got in 'Advanced settings' tab, 'Use global time' for Time Zone... so, it all seems fine, settings-wise However, on the chart itself, data is not showing for the Friday session, Fri NY time, which begins in Fri 23:30 Brisbane time zone, and ends Sat 05:59 Please see this: http://www.sierrachart.com/image.php?Image=1559935594356.png Now, experimenting, if I change the chart setting, and overwrite the session times, adding overnight session (which I don't really want, as this is just the cash market hrs), Day: 23:30 to 05:59 (Brisbane time zone, which are the correct NY cash market hours) Evening: 06:00 to 23:29 I do get a few more bars, but problems persist and new problems arise. Please see chart and comments here: http://www.sierrachart.com/image.php?Image=1559936748590.png 1) Why do I get overnight data at all? (this instrument doesn't trade overnight) 2) Get only a few more bar, and current session data is not shown Delete/download doesn't fix it Using intraday session times defined in the exchange time zone, and then using the brisbane time zone as global settings has worked smoothly with my futures, why is it working weird here? |
[2019-06-09 03:09:01] |
This is a chargeable support request at 75 USD per hour.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-09 03:09:08
