Date/Time: Thu, 05 Nov 2026 11:44:57 +0000
Two Alerts created work fine, want to set Order Entry from either one
View Count: 1062
[2019-06-07 18:38:33]
John M - Posts: 188
I have two alerts that work fine for order entry:
=AND(CROSSFROMBELOW(ID2.SG1,ID3.SG1), ID8.SG1>ID9.SG1)
and
=CROSSFROMBELOW(ID8.SG1,ID9.SG1)
I want to combine them into a single Alert for the Spreadsheet for Trading so Order Entry can enter from either one of them.
What is the syntax for an "Either/or" Alert setup? I have searched in the documentation but it's escaping me.
thank you.
[2019-06-08 10:24:25]
ForgivingComputers.com - Posts: 1251
If you want to combine two AND formulas so either one being true will be true, then put both of them in an OR function like this:
=OR(AND(CROSSFROMBELOW(ID2.SG1,ID3.SG1), ID8.SG1>ID9.SG1), CROSSFROMBELOW(ID8.SG1,ID9.SG1))
[2019-06-08 16:15:15]
John M - Posts: 188
Thank you, I always manage to mess up the syntax. I finally found the OR Boolean function and feasibly have a simpler method to enter the same thing in the Spreadsheet for Trading.
It's appreciated, thanks again.
[2019-06-09 13:03:39]
You use OR in the same way as you use the AND function. Refer to the information here:
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#OR_Function
