Date/Time: Sat, 18 May 2024 18:05:08 +0000
Comparing entry fill price to sc.Ask and sc.Bid
View Count: 685
[2019-06-05 01:39:35] |
Tom Hanks - Posts: 20 |
Hello, For the purposes of determining how far the price has moved since trade entry and modifying my attached stop orders I would like to compare the entry fill price to sc.Ask and sc.Bid. I am using the s_SCTradeOrder structure to pull my entry order fill price, but all of the options for this (Price1, AvgFillPrice, LastFillPrice) are doubles and sc.Ask/Bid are float. Do I need to convert the double to a float and round up or is there another way I should be doing this? |
[2019-06-05 04:59:43] |
You should use this function: sc.FormattedEvaluate() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-05 04:59:52
