Date/Time: Thu, 09 May 2024 20:30:19 +0000
Chart DOM Position Profit and Loss Column Not Appearing when
View Count: 846
[2019-06-04 19:55:08] |
User120942 - Posts: 71 |
I am currently using Sierra Chart Version # 1928. When I go into the Chart Settings > Advanced Settings tab and check the box for "Use Left Side Scale" the Chart DOM Position Profit and Loss Column does not display any values. I have attached an image of what I see in the Chart DOM Position Profit and Loss Column when the "Use Left Side Scale" is enabled and an image of when the "Use Left Side Scale" is disabled. Chart Trading and the Chart DOM: Chart DOM Position Profit and Loss Column I am not sure if this result is intended or an error. Your assistance is appreciated. Thank you |
Use Left Side Scale Disabled.png / V - Attached On 2019-06-04 19:53:47 UTC - Size: 173.44 KB - 340 views Use Left Side Scale Enabled.png / V - Attached On 2019-06-04 19:53:54 UTC - Size: 151.14 KB - 288 views |
[2019-06-06 19:23:35] |
We will be looking into this.
[2019-06-11 20:19:11] |
John - SC Support - Posts: 31501 |
Sorry for the delay on this. We have resolved this and the fix will be in the next Pre-Release (v 1934). When available, you can follow the instructions here to perform a Fast Update to this version: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-11 21:29:15] |
Thanks for your help. Much appreciated. |
