Date/Time: Mon, 06 May 2024 00:55:10 +0000
Settings and Inputs
View Count: 1114
[2013-11-27 14:09:10] |
User77549 - Posts: 1 |
I have attempted to change audible alerts to YES and signal text size to 15 several times on Index Wizard Trader, but my changes are always lost next time I log in, even though I save them as default settings. Please would you advise me on this.
[2013-11-27 16:35:41] |
Make sure you are saving your charts as a Chartbook and opening that same Chartbook when you start Sierra Chart. Here are instructions: https://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
