Date/Time: Thu, 02 May 2024 11:54:48 +0000
SierraChart debug with Visual Studio 2017 issue
View Count: 1246
[2019-06-04 08:24:35] |
User932967 - Posts: 18 |
I wrote a short test program, a trading system based on moving averages. I followed the instructions of the link: Step-By-Step ACSIL Debugging When I insert a breakpoint, Visual Studio tells me in an unusual way, with a message indicating that it will not be calculated. When finally I run the program in SierraChart through Trade-> AutoTrade System Bar Based BackTest or AutoTrade System Replay BackTest, calculations are performed regularly in SierraChart, but nothing happens in Visual Studio. BreakPoint: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=28935 |
[2019-06-04 08:28:49] |
Visual Studio screenshot: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=28936 |
Complete.jpg / V - Attached On 2019-06-04 08:28:08 UTC - Size: 371.14 KB - 448 views |
[2019-06-04 08:45:00] |
I think there is a problem with the compiler.. I'm going to reinstall it..
[2019-06-04 08:54:49] |
Yer, there is a compiler issue.. I reinstalled the compiler following the SierraChart link. I installed it regularly, but it doesn't work .. and I don't know what else to do.. https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=28937 |
compiler.jpg / V - Attached On 2019-06-04 08:54:27 UTC - Size: 103.27 KB - 551 views |
[2019-06-04 15:04:36] |
Solved!
[2020-09-22 15:33:02] |
User681150 - Posts: 62 |
solved how?? other people are having same problem. thanks for sharing |
[2020-09-22 17:33:08] |
What is the specific issue you are having?
