Date/Time: Sat, 27 Apr 2024 07:52:37 +0000
How to use TICKSIZE in formula?
View Count: 2631
[2013-03-21 12:31:16] |
mittalpa - Posts: 28 |
Hi In release 946, you added TICKSIZE identifier for alert formulae. I tried using it one formula but it didn't work.. maybe I am not using it correctly. I am on ver 947 and just wanted to add two ticks to the High of a bar as follows H+(2*TICKSIZE) Please provide a formula how to use it. Thanks AJ |
[2013-03-21 17:41:38] |
We tested this and it does work properly. That portion of the formula does look correct. There must be some other problem with the rest of the formula.
[2013-03-21 21:05:45] |
my bad.. the spelling was wrong. I have been wanting this since long. Now I can remove the tiresome spreadsheet. Thanks for adding it. |
