Date/Time: Sat, 18 May 2024 12:47:27 +0000
How to know what the maximum Historical Data limit
View Count: 821
[2019-06-03 14:35:40] |
Recoba71279 - Posts: 23 |
Hi I have a historical Forex USDJPY chart and the data has downloaded to 2007. Is this the furthest back it goes? Is there a listing of how far back the data for each symbol goes? If not how can I access more data? I have Chart Package 5 and Sierra Chart RT and Historical data feeds. Thanks |
[2019-06-03 23:14:46] |
Are you referring to an Intraday chart or a Historical Daily chart?
[2019-06-04 13:46:03] |
Historical Daily. I managed to DL back to June 1999. Still curious to know if there is a place where you indicate how far back the Historical Daily for Forex. Thanks |
[2019-06-05 04:48:41] |
There is no place where we indicate the amount of history per individual symbol and data type. For USDJPY there is data back to 1993. You do not have all of the data, refer to: No Historical Chart or Blank Chart | Historical Chart Not Updating | Missing Historical Chart Data: 6.5: Downloading Data Earlier than the First Date in the Data File And No Historical Chart or Blank Chart | Historical Chart Not Updating | Missing Historical Chart Data: 6.4: Missing Data in a Historical Chart Due to the Days to Load Setting to Low Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
