Date/Time: Sat, 18 May 2024 16:54:53 +0000
Edge to Edge Draw Style
View Count: 673
[2019-06-03 11:22:31] |
User120942 - Posts: 71 |
I would like to request that an SG draw style be added to display a horizontal line from "Edge to Edge". There are currently draw styles to draw a line from the "Line at Last Bar to Left Side" or as "Line at Last Bar to Edge" but it seems like there should be an option to draw a "Line from Edge to Edge" I use multiple studies on my charts that I prefer to have the study displayed as a horizontal line from Edge to Edge for better visibility. For example with the bar predictor studies for price action bar period types such as the GomRenko and Point and Figure bar types to see where the next bar will be created. And also with studies such as the bid ask prices. In order to display the studies as a horizontal line across the entire chart I use the workaround of adding two instances of each study. One with the draw style "Line at Last Bar to Edge" and the other instance with the draw style "Line at Last Bar to Left Side". The effectively creates a single horizontal bar from edge to edge. Please see the attached example of the GomRenko Bar Chart Type with the GomRenko Next Bar Level Study displayed as an edge to edge horizontal line. My request is for a single draw style that would eliminate the need to have to use duplicate studies to accomplish an edge to edge horizontal line. If there is a better alternative please let me know. Thank You |
Edge to Edge Draw Style.png / V - Attached On 2019-06-03 11:14:37 UTC - Size: 187.19 KB - 265 views |
[2019-06-04 10:45:10] |
This will be added to the next release.
[2019-06-04 16:28:33] |
Glad to hear. Thank You |
