Date/Time: Sat, 18 May 2024 17:04:46 +0000
Disable All Study Alerts
View Count: 1310
[2019-06-03 07:57:39] |
User513662 - Posts: 90 |
Hi, I have a chartbook which has 30 charts open, with various studies on each chart. I scan this chart book for setups, and create alerts for individual studies on selected charts (out of the 30). At the end of the session, it is hard to remember which of the 30 charts I have study alerts enabled. At the start of each day I want to have a clean slate with all study alerts disabled. At this stage I am having to either go through each study in each chart to disable (time consuming to say the least), or simply wait for them to trigger in the new day (invalid alert as they were set the previous day for different conditions). Both options are not really working well as one is either very time consuming, or having to deal with false alerts and clearing them throughout the new session. Is there a way to simply disable all study alerts so the check box is disabled? I cannot find any documentation on this. |
[2019-06-05 02:42:32] |
No there is not but we could see about adding an ACSIL function to do this. You could mute all alert sounds as an alternative: Global Settings Menu: Mute All Alert Sounds (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
