Date/Time: Sun, 28 Apr 2024 11:15:10 +0000
multiple querries
View Count: 654
[2019-05-31 13:33:08] |
User512854 - Posts: 24 |
Hi, 1- right now i fire say 100share buy or sell order at a time can i for example do it in the following way: say i have 10,000$ and i run the logic in sierra and each and every time i buy according to the balance i have from trading, is this possible? 2- it is possible to see the volatility of the trading account? to see the performance of the logic 2- is it possible to see the return % of the trading account? to check the logic over the years how much it is giving every year |
[2019-06-03 14:40:07] |
1. There is no built-in way to do this but you could develop a custom trading study to do this. Refer to: Automated Trading From an Advanced Custom Study 2, 3. Yes there are various trade statistics available which can be viewed for a particular account. Refer to: Trade Activity Log: Trade Statistics Tab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-12 17:39:14] |
Thanks. where i can see the return in % for the date range i select? ( whether year, 3months ,etc..)
