Date/Time: Wed, 08 May 2024 07:39:50 +0000
Prerealse 1053, 1054 - Login problem
View Count: 1150
[2013-11-27 07:59:31] |
ezfcharts00049 - Posts: 15 |
Hello, I have updated my 1051 Version with 1053 prerelease After logging out I always got the "This login exceeded the number..." window on login. I Still get the same no matter how long I am waiting for the next login & after computer restart as well. Got the same with Ver 1054 prerelease now, I have no access to my Sierra! please advise thanks |
[2013-11-27 08:10:26] |
We show you are logged in one of your computer systems. You appear to be using Sierra Chart on more than one system. Try again now, we temporarily increased the number of systems for you. If you are running Sierra Chart on more than one system, then with your particular account you can only use 1 system unless you have a direct account: http://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
